inventory [2018/11/23 13:53] – swalde | inventory [2022/04/14 03:40] – braeden.leislar | ||
3D Printers: | 3D Printers: | ||
- | * Solidoodle 3 with 20cm x 20cm x 20cm print area and heated bed, configured for ABS. | + | * [[Makerbot|MakerBot Replicator 2]] with 28cm x 15cm x 15cm print area, configured for PLA. |
- | * MakerBot Replicator 2 with 28cm x 15cm x 15cm print area, configured for PLA. | + | * Prusa MK3S |
+ | * Anycubic Photon S (SLA Resin Printer) | ||
- | Laser Cutters: | + | Laser Cutter: |
- | * Large cutter | + | * Ruida controller |
- | * Small cutter with 600mm x 400mm bed and 60W tube. | + | |
Electronics bench: | Electronics bench: | ||
Line 12: | Line 13: | ||
* Fixed temperature Weller soldering station. | * Fixed temperature Weller soldering station. | ||
* Korad dual power supply 0-30V 0-3A | * Korad dual power supply 0-30V 0-3A | ||
- | * MPJA Single power supply 0-30V 0-3A | ||
* Atten digital oscilloscope | * Atten digital oscilloscope | ||
* Toaster oven modified for reflow soldering. (with profile controller) | * Toaster oven modified for reflow soldering. (with profile controller) | ||
Line 36: | Line 36: | ||
In our "Dirty Room": | In our "Dirty Room": | ||
+ | * OMIO X6-2200l CNC router. (Can cut aluminium) | ||
* large bandsaw with wood blade | * large bandsaw with wood blade | ||
* small bandsaw with metal blade | * small bandsaw with metal blade | ||
Line 48: | Line 49: | ||
* dremel tools | * dremel tools | ||
* miter saw | * miter saw | ||
- | * table saw | + | * table saw (Upgraded December 2019) |
* skilsaw | * skilsaw | ||
* more hand tools | * more hand tools |
