smtstencil [2014/05/10 03:46] – srw7 | smtstencil [2015/11/24 01:04] – srw7 | ||
Line 19: | Line 19: | ||
Carefully place all SMT components on the board. | Carefully place all SMT components on the board. | ||
+ | Erik's smt stencil etching method | ||
+ | (more involved, but optimized for quicker etching time) | ||
+ | Steps 1-6 as before | ||
+ | - select all→right click→clone→3columns, | ||
+ | - select Leftmost board, edit width to be 0.1mm (toolbar on the left) (make sure " | ||
+ | - same as above, but with Rightmost board | ||
+ | - select all→right click→Scatter Group | ||
+ | - select all→right click→fill, | ||
+ | - zoom in to a small pad to check dpi setting - if lines are too far apart to get all the detail, increase scan dpi - if dpi is very high, it will take longer to etch | ||
+ | - if you decreased the dpi you may have to unfocus the laser and increase the power | ||
+ | - set velocity to 800 (it will go as fast as it can) and power to 30% | ||
+ | - carve out | ||
