inventory [2016/11/12 18:52] – srw7 | inventory [2022/04/14 03:48] – braeden.leislar | ||
3D Printers: | 3D Printers: | ||
- | * Solidoodle 3 with 20cm x 20cm x 20cm print area and heated bed, configured for ABS. | + | * [[Makerbot|MakerBot Replicator 2]] |
- | * MakerBot Replicator 2 with 28cm x 15cm x 15cm print area, configured | + | * [[Resin Printer|Anycubic Photon S (SLA Resin Printer)]] |
+ | * <del>Solidoodle 3 with 20cm x 20cm x 20cm print area and heated bed, configured for ABS. (down for rebuild)</ | ||
- | Laser Cutters: | + | Laser Cutter: |
- | * Large cutter | + | * Ruida controller |
- | * Small cutter with 600mm x 400mm bed and 60W tube. | + | |
Electronics bench: | Electronics bench: | ||
Line 12: | Line 12: | ||
* Fixed temperature Weller soldering station. | * Fixed temperature Weller soldering station. | ||
* Korad dual power supply 0-30V 0-3A | * Korad dual power supply 0-30V 0-3A | ||
- | * MPJA Single power supply 0-30V 0-3A | ||
* Atten digital oscilloscope | * Atten digital oscilloscope | ||
* Toaster oven modified for reflow soldering. (with profile controller) | * Toaster oven modified for reflow soldering. (with profile controller) | ||
Line 36: | Line 35: | ||
In our "Dirty Room": | In our "Dirty Room": | ||
+ | * OMIO X6-2200l CNC router. (Can cut aluminium) | ||
* large bandsaw with wood blade | * large bandsaw with wood blade | ||
* small bandsaw with metal blade | * small bandsaw with metal blade | ||
Line 47: | Line 47: | ||
* jigsaw | * jigsaw | ||
* dremel tools | * dremel tools | ||
- | * chop saw | + | * miter saw |
- | * table saw | + | * table saw (Upgraded December 2019) |
* skilsaw | * skilsaw | ||
* more hand tools | * more hand tools |
