inventory [2016/01/22 16:15] – [Inventory] srw7inventory [2022/07/17 03:29] (current) swalde
-NOTEThis page is COMPLETELY out of date, and shouldn't be relied on.  Is it time to delete itor will someone take the time to update it?+====3D Printers:====
 +  * [[Makerbot|MakerBot Replicator 2]]
 +  * [[Ender3v2|Ender 3 V2]]
 +  * [[Resin Printer|Anycubic Photon S (SLA Resin Printer)]]
 +  * <del>Solidoodle 3 with 20cm x 20cm x 20cm print area and heated bedconfigured for ABS. (down for rebuild)</del>
-===== Inventory ===== +====Laser Cutter:====
-Please add things you are leasing or giving to the space.+  * Ruida controller with 1300mm x 1020mm bed and 130W tube.
-==== Furniture ==== +====Electronics bench:====
-^ Item ^ Lessee ^ Description ^ +  * Aouye soldering station with adjustable iron and hot air rework gun.
-| Work Benches | SKTechWorks | 4 - 2' x 8' benches against walls | +  * Adjustable Weller soldering station.
-| Bins | SKTechWorks | 20 Rubbermaid Bins | +  * Fixed temperature Weller soldering station.
-| Bookshelf | Kurtis Wanner | | +  * Korad dual power supply 0-30V 0-3A
-| Bar Fridge | Kurtis Wanner | |+  * Atten digital oscilloscope
 +  * Toaster oven modified for reflow soldering. (with profile controller)
 +  * plus a variety of multimeters, older oscilloscopes, function generators, a frequency counter, and hand tools.
-=== Electronics === +===="Community" computers:====
-^ Item ^ Lessee ^ Description ^ +  * Spacebox is a reasonably current computer available for use by members and is used for a variety of things including CADCAMembedded programmingand general internet use
-| Continuous Inkjet Printer | Kurtis Wanner | Can print cds/dvds - Needs heads cleaned | +  * There are also several laptops with Windows 7 and Windows 10 that are available for members' use for things such as Arduino programming and 3D model prep. (for the 3D printers)
-| Hakko 936 soldering stations (2) | Andrew Bergman, Ryan Silk | Not sure if Andrew'is fair game. | +
-| Weller soldering station | James Cooper | Fair game, but please clean after use +
-| Weller soldering iron | Kurtis Wanner | Fair gameplease use. | +
-| Several other soldering irons | Paul Chavady? | | +
-| Astroflite battery charger | Kurtis Wanner | Should workhaven't tried since I got it| +
-| Roomba robot vacuum | Kurtis Wanner | dead battery - fix and use to clean the space! | +
-| 0-30V, 0-3A bench power supply | James Cooper | | +
-| 12V, 10A car battery charger | James Cooper | | +
-| [[http://www.sparkfun.com/products/9857 | SUMP Logic Analyzer ]] | James Cooper | | +
-| [[http://www.sparkfun.com/products/9484 | Basic DIY Oscilloscope]] | James Cooper | |+
-=== Tools === +====Hand tools:====
-^ Item ^ Lessee ^ Description ^ +  * screwdrivers
-| Compound mitre saw | SKTechWorks | |  +  * pliers
-| Drill press (Jobmate) | Ryan Silk | | +  * wrenches
-| Drill press (Black & Decker) | James Cooper | It's noisy, but it works | +  * crimpers
-| Screwdriver set | SKTechWorks | | +  * wire cutters / strippers
-| Corded drill (Jobmate) | Paul Chavady | | +  * files
-| Corded drill (DeWalt) | James Cooper, Ryan Silk | | +  * nibbler
-| Cordless drill | SKTechWorks | | +  * squares
-| Jigsaw (Black & Decker) | James Cooper | | +  * levels
-| Jigsaw (Ryobi) | Paul Chavady | | +  * hammers
-| Bandsaw (Jobmate) | Tim Fretz | Band is ruined; almost impossible to get replacements |+  * brushes
 +  * and more
-=== Books === +====In our "Wood Room":====
-^ Item ^ Lessee ^ Description ^ +  * "Laguna" our CNC router with approximately 48" x 48" bed. (Good for woods and plastics
-| MAKE Magazines (#20,21,22| Kurtis Wanner | | +  * large bandsaw with wood blade
-| Servo Magazines (Vol7 No3 - present) | Kurtis Wanner | | +  * miter saw
-| ROBOT Magazines (2005 #1 - present) | Kurtis Wanner | |  +  * table saw (Upgraded 2022
-| 2600 Magazines | Tim Fretz | Assortment of 2600 Magazines | +  * scroll saw
-| Popular Science (2), Popular Mechanics (4) | Kurtis Wanner | (plus 1 American Science) | +
-| Maxim Magazines (28 issues) | Kurtis Wanner | (also a FHM) | +
-| Stiquito for Beginners | Kurtis Wanner | re: shape-memory alloy, aka muscle wire | +
-| Robot Builders Bonanza | Kurtis Wanner | |  +
-| Build Your Own Combat Robot | Kurtis Wanner | includes autonomous like minisumo too | +
-| Forest Mims - Getting Started in Electronics | Kurtis Wanner | |  +
-| Pyrotechnics & Fireworks Manuals | Kurtis Wanner | | +
-==== Electrical Engineering Reference Textbooks ==== +====In our "Metal Room":====
-Textbooks from Electrical Engineering. Owned by Kurtis Wanner. For sale if you need them! +  * OMIO X6-2200l CNC router. (Can cut aluminium)
-  * Circuit Analysis Robbins & Miller +  * large drill press
-  * Electronic Materials & Devices - Kasap +  * bench grinder
-  * Electronics Principles - Malvino +  * small bench sander
-  * Electric Circuits - Dorf, Svoboda +  * cordless drills
-  * Feedback Control of Dynamic Systems - Franklin, Powell +  * jigsaw
-  * Power Systems Analysis - Hadi, Saadat +  * dremel tools
-  * Real Time Systems Design & Analysis - Laplante +  * skilsaw
-  * Signal Processing & Linear Systems - Lathi +  * more hand tools
-  * Engineering Mechanics: Statics & Dynamics - Hibbeler +  * 12" x 36" metal lathe (requires special training)
-  * Digital Systems - Tocci, Widmer +
-  * The 8051 Microcontroller - Ayala +In the Library:
-  * Ethics in Engineering - Martin, Schinzinger +  * there are a surprising variety of books available on topics ranging from beginner electronics to advanced materials science.
-  * Pocket Guide to Technical Writing - Pfeiffer +
-  * Effective Business Communication - MacLennan +===== Inventory =====
-  * Single Variable Calculus: Study Guide & Solution Manual - Stewart +Please add things you are leasing or giving to the space.
-  * Design for Electrical and Computer Engineers - Salt, Rothery+
inventory.txt · Last modified: 2022/07/17 03:29 by swalde
