inventory [2016/01/22 16:15] – [Inventory] srw7 | inventory [2022/04/14 03:48] – braeden.leislar | ||
- | NOTE: This page is COMPLETELY out of date, and shouldn' | + | 3D Printers: |
+ | * [[Makerbot|MakerBot Replicator 2]] | ||
+ | * [[Resin Printer|Anycubic Photon S (SLA Resin Printer)]] | ||
- | ===== Inventory ===== | + | Laser Cutter: |
- | Please add things you are leasing or giving to the space. | + | * Ruida controller with 1300mm x 1020mm bed and 130W tube. |
- | ==== Furniture ==== | + | Electronics bench: |
- | ^ Item ^ Lessee ^ Description ^ | + | * Aouye soldering station with adjustable iron and hot air rework gun. |
- | | Work Benches | SKTechWorks | 4 - 2' x 8' benches against walls | | + | * Adjustable Weller soldering station. |
- | | Bins | SKTechWorks | 20 - Rubbermaid Bins | | + | * Fixed temperature Weller soldering station. |
- | | Bookshelf | Kurtis Wanner | | | + | * Korad dual power supply 0-30V 0-3A |
- | | Bar Fridge | Kurtis Wanner | | | + | * Atten digital oscilloscope |
+ | * Toaster oven modified for reflow soldering. (with profile controller) | ||
+ | * plus a variety of multimeters, | ||
- | === Electronics === | + | " |
- | ^ Item ^ Lessee ^ Description ^ | + | * Spacebox |
- | | Continuous Inkjet Printer | Kurtis Wanner | Can print cds/dvds - Needs heads cleaned | | + | * There are also several laptops with Windows 7 and Windows 10 that are available for members' |
- | | Hakko 936 soldering stations (2) | Andrew Bergman, Ryan Silk | Not sure if Andrew' | + | |
- | | Weller soldering station | James Cooper | Fair game, but please clean after use | | + | |
- | | Weller soldering iron | Kurtis Wanner | Fair game, please use. | | + | |
- | | Several other soldering irons | Paul Chavady, ? | | | + | |
- | | Astroflite battery charger | Kurtis Wanner | Should work, haven' | + | |
- | | Roomba robot vacuum | Kurtis Wanner | dead battery - fix and use to clean the space! | | + | |
- | | 0-30V, 0-3A bench power supply | James Cooper | | | + | |
- | | 12V, 10A car battery charger | James Cooper | | | + | |
- | | [[http:// | + | |
- | === Tools === | + | Hand tools: |
- | ^ Item ^ Lessee ^ Description ^ | + | * screwdrivers |
- | | Compound mitre saw | SKTechWorks | | | + | * pliers |
- | | Drill press (Jobmate) | Ryan Silk | | | + | * wrenches |
- | | Drill press (Black & Decker) | James Cooper | It's noisy, but it works | | + | * crimpers |
- | | Screwdriver set | SKTechWorks | | | + | * wire cutters / strippers |
- | | Corded drill (Jobmate) | Paul Chavady | | | + | * files |
- | | Corded drill (DeWalt) | James Cooper, Ryan Silk | | | + | * nibbler |
- | | Cordless drill | SKTechWorks | | | + | * squares |
- | | Jigsaw (Black & Decker) | James Cooper | | | + | * levels |
- | | Jigsaw (Ryobi) | Paul Chavady | | | + | * hammers |
- | | Bandsaw (Jobmate) | Tim Fretz | Band is ruined; almost impossible to get replacements | | + | * brushes |
+ | * and more | ||
- | === Books === | + | In our "Dirty Room": |
- | ^ Item ^ Lessee ^ Description ^ | + | * " |
- | | MAKE Magazines | + | * OMIO X6-2200l CNC router. |
- | | Servo Magazines (Vol7 No3 - present) | Kurtis Wanner | | | + | * large bandsaw with wood blade |
- | | ROBOT Magazines | + | * small bandsaw with metal blade |
- | | 2600 Magazines | Tim Fretz | Assortment of 2600 Magazines | | + | * large drill press |
- | | Popular Science (2), Popular Mechanics (4) | Kurtis Wanner | (plus 1 American Science) | | + | * small drill press |
- | | Maxim Magazines | + | * bench grinder |
- | | Stiquito for Beginners | Kurtis Wanner | re: shape-memory alloy, aka muscle wire | | + | * scroll saw |
- | | Robot Builders Bonanza | Kurtis Wanner | | | + | * small bench sander |
- | | Build Your Own Combat Robot | Kurtis Wanner | includes autonomous like minisumo too | | + | * cordless drills |
- | | Forest Mims - Getting Started in Electronics | Kurtis Wanner | | | + | * jigsaw |
- | | Pyrotechnics & Fireworks Manuals | Kurtis Wanner | | | + | * dremel tools |
+ | * miter saw | ||
+ | * table saw (Upgraded December 2019) | ||
+ | * skilsaw | ||
+ | * more hand tools | ||
+ | * 12" x 36" metal lathe (requires special training) | ||
- | ==== Electrical Engineering Reference Textbooks | + | In the Library: |
- | Textbooks from Electrical Engineering. Owned by Kurtis Wanner. For sale if you need them! | + | * there are a surprising variety of books available on topics ranging from beginner electronics to advanced materials science. |
- | * Circuit Analysis - Robbins & Miller | + | |
- | * Electronic Materials & Devices - Kasap | + | ===== Inventory ===== |
- | * Electronics Principles - Malvino | + | Please add things |
- | * Electric Circuits - Dorf, Svoboda | + | |
- | * Feedback Control of Dynamic Systems - Franklin, Powell | + | |
- | * Power Systems Analysis - Hadi, Saadat | + | |
- | * Real Time Systems Design & Analysis - Laplante | + | |
- | * Signal Processing & Linear Systems - Lathi | + | |
- | * Engineering Mechanics: Statics & Dynamics - Hibbeler | + | |
- | * Digital Systems - Tocci, Widmer | + | |
- | * The 8051 Microcontroller - Ayala | + | |
- | * Ethics in Engineering - Martin, Schinzinger | + | |
- | * Pocket Guide to Technical Writing - Pfeiffer | + | |
- | * Effective Business Communication - MacLennan | + | |
- | * Single Variable Calculus: Study Guide & Solution Manual - Stewart | + | |
- | * Design for Electrical and Computer Engineers - Salt, Rothery | + | |
