Both sides previous revisionPrevious revision | Next revisionBoth sides next revision | ||
smtstencil [2017/05/25 16:54] – swalde | smtstencil [2019/07/03 18:41] – swalde | ||
Line 38: | Line 38: | ||
- | ==Gerber to DXF== | + | ==Gerber to DXF (New, even more complicated workflow)== |
+ | Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/ | ||
+ | Simple! | ||
+ | - Open the GTP file in Gerbv | ||
+ | - Export as PNG, 1016 dpi (this is arbitrary and is a leftover from a previous attempted workflow) | ||
+ | - Load PNG into GIMP | ||
+ | - Set DPI in Image-> | ||
+ | - Colour-> | ||
+ | - Colour-> | ||
+ | - Select-> | ||
+ | - Select-> | ||
+ | - New Layer, white background | ||
+ | - Fill (whole selection) with black | ||
+ | - delete original layer | ||
+ | - Export as PNG | ||
+ | - Load PNG into Inkscape | ||
+ | - Trace Bitmap | ||
+ | - delete bitmap | ||
+ | - Note dimensions in mm | ||
+ | - save as DXF | ||
+ | - Load into Smartcarve | ||
+ | - Set the dimensions | ||
+ | ==Gerber to DXF (This one failed with 45 degree rounded-end pads. gerbv totally screwed up the export)== | ||
Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/ | Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/ |
