smtstencil [2015/11/24 01:02] – srw7 | smtstencil [2019/07/03 18:41] – swalde | ||
Line 29: | Line 29: | ||
- select all→right click→clone→3columns, | - select all→right click→clone→3columns, | ||
- select Leftmost board, edit width to be 0.1mm (toolbar on the left) (make sure " | - select Leftmost board, edit width to be 0.1mm (toolbar on the left) (make sure " | ||
- | - same as step 9, but with Rightmost board | + | - same as above, but with Rightmost board |
- select all→right click→Scatter Group | - select all→right click→Scatter Group | ||
- select all→right click→fill, | - select all→right click→fill, | ||
Line 36: | Line 36: | ||
- set velocity to 800 (it will go as fast as it can) and power to 30% | - set velocity to 800 (it will go as fast as it can) and power to 30% | ||
- carve out | - carve out | ||
+ | ==Gerber to DXF (New, even more complicated workflow)== | ||
+ | Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/ | ||
+ | Simple! | ||
+ | - Open the GTP file in Gerbv | ||
+ | - Export as PNG, 1016 dpi (this is arbitrary and is a leftover from a previous attempted workflow) | ||
+ | - Load PNG into GIMP | ||
+ | - Set DPI in Image-> | ||
+ | - Colour-> | ||
+ | - Colour-> | ||
+ | - Select-> | ||
+ | - Select-> | ||
+ | - New Layer, white background | ||
+ | - Fill (whole selection) with black | ||
+ | - delete original layer | ||
+ | - Export as PNG | ||
+ | - Load PNG into Inkscape | ||
+ | - Trace Bitmap | ||
+ | - delete bitmap | ||
+ | - Note dimensions in mm | ||
+ | - save as DXF | ||
+ | - Load into Smartcarve | ||
+ | - Set the dimensions | ||
+ | ==Gerber to DXF (This one failed with 45 degree rounded-end pads. gerbv totally screwed up the export)== | ||
+ | Simple! | ||
+ | I did this all on Linux, so if things work different on Windows, please let me know. | ||
+ | Use **gerbv** to open the gerber file. Look at it. Use the Measure tool to measure some easy-to-repeat dimension. | ||
+ | Open that SVG file in **Inkscape**. | ||
+ | Now, open that DXF in **LibreCAD**. (This step might not be necessary, but follow along for now.) Remember that dimension I asked you to measure? | ||
