| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| smtstencil [2017/05/25 16:54] – swalde | smtstencil [2020/11/04 18:02] (current) – swalde | ||
| Line 38: | Line 38: | ||
| - | ==Gerber to DXF== | + | ==Gerber to DXF (New, even more complicated workflow)== |
| + | Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/ | ||
| + | Simple! | ||
| + | - Open the GTP file in Gerbv | ||
| + | - Export as PNG, 1016 dpi (this is arbitrary and is a leftover from a previous attempted workflow) | ||
| + | - Load PNG into GIMP | ||
| + | - Set DPI in Image-> | ||
| + | - Colour-> | ||
| + | - Colour-> | ||
| + | - Select-> | ||
| + | - Select-> | ||
| + | - New Layer, white background | ||
| + | - Fill (whole selection) with black | ||
| + | - delete original layer | ||
| + | - Export as PNG | ||
| + | - Load PNG into Inkscape | ||
| + | - Trace Bitmap | ||
| + | - delete bitmap | ||
| + | - Note dimensions in mm | ||
| + | - save as DXF | ||
| + | - Load into Smartcarve | ||
| + | - Set the dimensions | ||
| + | - New possible process from here? (avoids having to " | ||
| + | - In The Gimp, choose Selection-> | ||
| + | - Open the paths dock. Right-click on the path and choose " | ||
| + | - Name the SVG file to export. | ||
| + | ==Gerber to DXF (This one failed with 45 degree rounded-end pads. gerbv totally screwed up the export)== | ||
| Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/ | Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/ | ||
