stratum1ntp [2019/08/21 20:01] andrewstratum1ntp [2021/11/28 02:51] (current) andrew
-====== Stratum 1 NTP Setup on Raspberry Pi By: Bun-Bun & guppy ======+====== Stratum 1 NTP Setup on Raspberry Pi ======
 +== By: Bun-Bun & guppy ==
Line 10: Line 11:
 +dtoverlay=pi3-disable-wifi
Line 138: Line 140:
   * https://www.ntpsec.org/white-papers/stratum-1-microserver-howto/   * https://www.ntpsec.org/white-papers/stratum-1-microserver-howto/
-  * Add nohz=off to the end of the line in /etc/cmdline.txt+  * Add nohz=off to the end of the line in /boot/cmdline.txt
   * configure system to run cpu full speed   * configure system to run cpu full speed
     * <code>apt -y install cpufrequtils     * <code>apt -y install cpufrequtils
Line 149: Line 151:
 apt -y autoremove apt -y autoremove
 apt clean apt clean
 +</code>
 +    * <code>crontab -e
 </code> </code>
stratum1ntp.txt · Last modified: 2021/11/28 02:51 by andrew
