stratum1ntp [2019/08/21 19:39] – andrew | stratum1ntp [2021/10/22 20:35] – andrew | ||
====== Stratum 1 NTP Setup on Raspberry Pi ====== | ====== Stratum 1 NTP Setup on Raspberry Pi ====== | ||
+ | == By: Bun-Bun & guppy == | ||
* This guides uses Uputronics Raspberry Pi+ GPS Expansion Board and a rpi3 or newer | * This guides uses Uputronics Raspberry Pi+ GPS Expansion Board and a rpi3 or newer | ||
* Setup rpi with latest Raspbian, enable ssh, etc... | * Setup rpi with latest Raspbian, enable ssh, etc... | ||
Line 137: | Line 139: | ||
* https:// | * https:// | ||
- | * Add nohz=off to the end of the line in /etc/ | + | * Add nohz=off to the end of the line in /boot/ |
* configure system to run cpu full speed | * configure system to run cpu full speed | ||
Line 143: | Line 145: | ||
systemctl restart cpufrequtils</ | systemctl restart cpufrequtils</ | ||
* Remove useless stuff | * Remove useless stuff | ||
- | apt -y purge wpasupplicant | + | systemctl stop avahi-daemon |
- | apt -y purge alsa-utils | + | systemctl disable avahi-daemon |
- | systemctl stop raspbian | + | |
- | systemctl disable | + | |
apt -y autoremove | apt -y autoremove | ||
apt clean | apt clean | ||
+ | * Set serial to low latency | ||
+ | @reboot setserial / | ||
