stratum1ntp [2019/08/20 05:23] andrewstratum1ntp [2021/11/28 02:51] (current) andrew
 ====== Stratum 1 NTP Setup on Raspberry Pi ====== ====== Stratum 1 NTP Setup on Raspberry Pi ======
 +== By: Bun-Bun & guppy ==
   * Setup rpi with latest Raspbian, enable ssh, etc...   * Setup rpi with latest Raspbian, enable ssh, etc...
Line 9: Line 11:
 +dtoverlay=pi3-disable-wifi
Line 115: Line 118:
   * {{ntpsetup.tar|gpsControl files and install.sh}} #for stationary mode (Credit to guppy for creating and Bun-Bun for correcting)   * {{ntpsetup.tar|gpsControl files and install.sh}} #for stationary mode (Credit to guppy for creating and Bun-Bun for correcting)
     * Download linked tar     * Download linked tar
 +      * wget -O ntpsetup.tar http://wiki.sktechworks.ca/lib/exe/fetch.php?media=ntpsetup.tar
     * tar -xvf ntpsetup.tar     * tar -xvf ntpsetup.tar
     * cd ntpsetup     * cd ntpsetup
Line 120: Line 124:
     * This copies the gpscontrol files and creates/enables its service. Also makes a gpsd requirement for ntp     * This copies the gpscontrol files and creates/enables its service. Also makes a gpsd requirement for ntp
   * Disable NTP from dhcp   * Disable NTP from dhcp
-    * echo "" > /etc/dhcp/dhclient-exit-hooks.d/ntp +    * <code>
-    echo "" > /var/lib/ntp/ntp.conf.dhcp +echo "" > /etc/dhcp/dhclient-exit-hooks.d/ntp
-    chattr +i /etc/dhcp/dhclient-exit-hooks.d/ntp +echo "" > /var/lib/ntp/ntp.conf.dhcp
-    chattr +i /var/lib/ntp/ntp.conf.dhcp+chattr +i /etc/dhcp/dhclient-exit-hooks.d/ntp
 +chattr +i /var/lib/ntp/ntp.conf.dhcp
 +</code>
   * reboot   * reboot
   * gpsmon #also cgps -s   * gpsmon #also cgps -s
Line 133: Line 139:
 ====== Optimizations ====== ====== Optimizations ======
-  * Add nohz=off to the end of the line in /etc/cmdline.txt+  * https://www.ntpsec.org/white-papers/stratum-1-microserver-howto/
 +  * Add nohz=off to the end of the line in /boot/cmdline.txt
   * configure system to run cpu full speed   * configure system to run cpu full speed
     * <code>apt -y install cpufrequtils     * <code>apt -y install cpufrequtils
-echo 'GOVERNOR="performance"' > /etc/default/cpufrequtils +echo 'GOVERNOR="performance"' > /etc/default/cpufrequtils
-systemctl restart cpufrequtils</code>+systemctl restart cpufrequtils</code>
   * Remove useless stuff   * Remove useless stuff
-    * <code>apt -y purge bluez triggerhappy +    * <code>apt -y purge bluez triggerhappy wpasupplicant alsa-utils
-apt purge wpasupplicant +systemctl stop avahi-daemon
-apt-get remove alsa-utils +systemctl disable avahi-daemon
-systemctl stop raspbian avahi-daemon +apt -y autoremove
-systemctl disable raspbian avahi-daemon +
-apt autoremove+
 apt clean apt clean
 +</code>
 +    * <code>crontab -e
 </code> </code>
stratum1ntp.txt · Last modified: 2021/11/28 02:51 by andrew
