stratum1ntp [2019/07/24 16:31] andrewstratum1ntp [2021/11/28 02:51] (current) andrew
 ====== Stratum 1 NTP Setup on Raspberry Pi ====== ====== Stratum 1 NTP Setup on Raspberry Pi ======
 +== By: Bun-Bun & guppy ==
   * Setup rpi with latest Raspbian, enable ssh, etc...   * Setup rpi with latest Raspbian, enable ssh, etc...
Line 5: Line 7:
   * raspi-config #disable linux from trying to access console getty   * raspi-config #disable linux from trying to access console getty
     * 5 Interfacing Options      * 5 Interfacing Options
-    * P6 Serial -> Login Shell (no) +    * P6 Serial -> Login Shell (no) -> Enable Hardware (yes)
   * vi /boot/config.txt   * vi /boot/config.txt
 +dtoverlay=pi3-disable-wifi
Line 34: Line 37:
   * vi /etc/ntp.conf   * vi /etc/ntp.conf
     * Change servers as appropriate, stuff at the bottom is the gpsd and pps link     * Change servers as appropriate, stuff at the bottom is the gpsd and pps link
 +    * Can have no servers and only use gps/pps as source, or have more than 1 other. Two sources (yourself and some other server) is bad.
     * <code>     * <code>
 # Enable this if you want statistics to be logged. # Enable this if you want statistics to be logged.
Line 110: Line 114:
 # Other options you want to pass to gpsd # Other options you want to pass to gpsd
-GPSD_OPTIONS=-n""+GPSD_OPTIONS="-n"
 </code> </code>
   * {{ntpsetup.tar|gpsControl files and install.sh}} #for stationary mode (Credit to guppy for creating and Bun-Bun for correcting)   * {{ntpsetup.tar|gpsControl files and install.sh}} #for stationary mode (Credit to guppy for creating and Bun-Bun for correcting)
     * Download linked tar     * Download linked tar
 +      * wget -O ntpsetup.tar http://wiki.sktechworks.ca/lib/exe/fetch.php?media=ntpsetup.tar
     * tar -xvf ntpsetup.tar     * tar -xvf ntpsetup.tar
-    * cd ntpsetup.tar+    * cd ntpsetup
     * ./install.sh     * ./install.sh
     * This copies the gpscontrol files and creates/enables its service. Also makes a gpsd requirement for ntp     * This copies the gpscontrol files and creates/enables its service. Also makes a gpsd requirement for ntp
   * Disable NTP from dhcp   * Disable NTP from dhcp
-    * echo "" > /etc/dhcp/dhclient-exit-hooks.d/ntp +    * <code>
-    echo "" > /var/lib/ntp/ntp.conf.dhcp +echo "" > /etc/dhcp/dhclient-exit-hooks.d/ntp
-    chattr +i /etc/dhcp/dhclient-exit-hooks.d/ntp +echo "" > /var/lib/ntp/ntp.conf.dhcp
-    chattr +i /var/lib/ntp/ntp.conf.dhcp+chattr +i /etc/dhcp/dhclient-exit-hooks.d/ntp
 +chattr +i /var/lib/ntp/ntp.conf.dhcp
 +</code>
   * reboot   * reboot
   * gpsmon #also cgps -s   * gpsmon #also cgps -s
Line 129: Line 136:
     * http://www.unixwiz.net/techtips/raspberry-pi3-gps-time.html     * http://www.unixwiz.net/techtips/raspberry-pi3-gps-time.html
     * https://ava.upuaut.net/?p=951     * https://ava.upuaut.net/?p=951
 +====== Optimizations ======
 +  * https://www.ntpsec.org/white-papers/stratum-1-microserver-howto/
 +  * Add nohz=off to the end of the line in /boot/cmdline.txt
 +  * configure system to run cpu full speed
 +    * <code>apt -y install cpufrequtils
 +echo 'GOVERNOR="performance"' > /etc/default/cpufrequtils
 +systemctl restart cpufrequtils</code>
 +  * Remove useless stuff
 +    * <code>apt -y purge bluez triggerhappy wpasupplicant alsa-utils
 +systemctl stop avahi-daemon
 +systemctl disable avahi-daemon
 +apt -y autoremove
 +apt clean
 +</code>
 +    * <code>crontab -e
 +</code>
stratum1ntp.txt · Last modified: 2021/11/28 02:51 by andrew
