stratum1ntp [2019/07/24 16:28] – andrew | stratum1ntp [2021/10/22 20:35] – andrew | ||
====== Stratum 1 NTP Setup on Raspberry Pi ====== | ====== Stratum 1 NTP Setup on Raspberry Pi ====== | ||
+ | == By: Bun-Bun & guppy == | ||
* This guides uses Uputronics Raspberry Pi+ GPS Expansion Board and a rpi3 or newer | * This guides uses Uputronics Raspberry Pi+ GPS Expansion Board and a rpi3 or newer | ||
* Setup rpi with latest Raspbian, enable ssh, etc... | * Setup rpi with latest Raspbian, enable ssh, etc... | ||
Line 5: | Line 7: | ||
* raspi-config #disable linux from trying to access console getty | * raspi-config #disable linux from trying to access console getty | ||
* 5 Interfacing Options | * 5 Interfacing Options | ||
- | * P6 Serial -> Login Shell (no) | + | * P6 Serial -> Login Shell (no) -> Enable Hardware (yes) |
* vi / | * vi / | ||
* Add the following to the bottom | * Add the following to the bottom | ||
Line 34: | Line 36: | ||
* Change servers as appropriate, | * Change servers as appropriate, | ||
+ | * Can have no servers and only use gps/pps as source, or have more than 1 other. Two sources (yourself and some other server) is bad. | ||
# Enable this if you want statistics to be logged. | # Enable this if you want statistics to be logged. | ||
Line 47: | Line 50: | ||
#server ntp.your-provider.example | #server ntp.your-provider.example | ||
+ | #Can have no servers and only use gps/pps as source, or have more than 1 other. Two sources (yourself and some other server) is bad. | ||
#server tock.usask.ca | #server tock.usask.ca | ||
#server ntp2.torix.ca | #server ntp2.torix.ca | ||
- | server ntp.zaf.ca | + | #server ntp.zaf.ca |
# Access control configuration; | # Access control configuration; | ||
Line 89: | Line 93: | ||
server 127.127.28.0 minpoll 4 maxpoll 4 iburst prefer | server 127.127.28.0 minpoll 4 maxpoll 4 iburst prefer | ||
fudge 127.127.28.0 time1 +0.105 flag1 1 refid GPSD stratum 1 | fudge 127.127.28.0 time1 +0.105 flag1 1 refid GPSD stratum 1 | ||
- | tos mindist 0.015 #something about ignoring | + | tos mindist 0.015 #something about accepting |
* apt-get install gpsd gpsd-clients | * apt-get install gpsd gpsd-clients | ||
Line 109: | Line 113: | ||
# Other options you want to pass to gpsd | # Other options you want to pass to gpsd | ||
- | GPSD_OPTIONS=-n"" | + | GPSD_OPTIONS="-n" |
* {{ntpsetup.tar|gpsControl files and install.sh}} #for stationary mode (Credit to guppy for creating and Bun-Bun for correcting) | * {{ntpsetup.tar|gpsControl files and install.sh}} #for stationary mode (Credit to guppy for creating and Bun-Bun for correcting) | ||
* Download linked tar | * Download linked tar | ||
+ | * wget -O ntpsetup.tar http:// | ||
* tar -xvf ntpsetup.tar | * tar -xvf ntpsetup.tar | ||
- | * cd ntpsetup.tar | + | * cd ntpsetup |
* This copies the gpscontrol files and creates/ | * This copies the gpscontrol files and creates/ | ||
* Disable NTP from dhcp | * Disable NTP from dhcp | ||
- | * echo "" | + | * < |
- | | + | echo "" |
- | | + | echo "" |
- | | + | chattr +i / |
+ | chattr +i / | ||
* reboot | * reboot | ||
* gpsmon #also cgps -s | * gpsmon #also cgps -s | ||
Line 128: | Line 135: | ||
* http:// | * http:// | ||
* https:// | * https:// | ||
+ | ====== Optimizations ====== | ||
+ | * https:// | ||
+ | * Add nohz=off to the end of the line in / | ||
+ | * configure system to run cpu full speed | ||
+ | echo ' | ||
+ | systemctl restart cpufrequtils</ | ||
+ | * Remove useless stuff | ||
+ | systemctl stop avahi-daemon | ||
+ | systemctl disable avahi-daemon | ||
+ | apt -y autoremove | ||
+ | apt clean | ||
+ | * Set serial to low latency | ||
+ | @reboot setserial / | ||
