Both sides previous revisionPrevious revision | Last revisionBoth sides next revision | ||
smtstencil [2019/07/03 18:41] – swalde | smtstencil [2020/11/04 17:42] – swalde | ||
Line 51: | Line 51: | ||
- Colour-> | - Colour-> | ||
- Select-> | - Select-> | ||
- | - Select-> | + | - Select-> |
- New Layer, white background | - New Layer, white background | ||
- Fill (whole selection) with black | - Fill (whole selection) with black | ||
Line 63: | Line 63: | ||
- Load into Smartcarve | - Load into Smartcarve | ||
- Set the dimensions | - Set the dimensions | ||
+ | - New possible process from here? (avoids having to " | ||
+ | - In The Gimp, choose Selection-> | ||
+ | - Open the paths dock. Right-click on the path and choose " | ||
+ | - Name the SVG file to export. | ||
==Gerber to DXF (This one failed with 45 degree rounded-end pads. gerbv totally screwed up the export)== | ==Gerber to DXF (This one failed with 45 degree rounded-end pads. gerbv totally screwed up the export)== |
