smtstencil [2017/05/25 16:54] swaldesmtstencil [2020/11/04 18:02] (current) swalde
Line 38: Line 38:
-==Gerber to DXF==+==Gerber to DXF (New, even more complicated workflow)==
 +Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/KiCAD) and your laser takes DXF and I can't find a free Gerber to DXF converter.  What do I do?
 +Simple!  (Not really, but it seems to work)
 +  - Open the GTP file in Gerbv
 +  - Export as PNG, 1016 dpi (this is arbitrary and is a leftover from a previous attempted workflow)
 +  - Load PNG into GIMP
 +  - Set DPI in Image->Print Size.  Take note of dimensions in mm
 +  - Colour->Invert
 +  - Colour->Threshold (about 3/4)
 +  - Select->By Colour, click black
 +  - Select->Shrink Selection (5 seems to be good)*
 +  - New Layer, white background
 +  - Fill (whole selection) with black
 +  - delete original layer
 +  - Export as PNG
 +  - Load PNG into Inkscape
 +  - Trace Bitmap
 +  - delete bitmap
 +  - Note dimensions in mm
 +  - save as DXF
 +  - Load into Smartcarve
 +  - Set the dimensions
 +  - New possible process from here? (avoids having to "trace" again in inkscape)
 +  - In The Gimp, choose Selection->To Path.
 +  - Open the paths dock.  Right-click on the path and choose "export"
 +  - Name the SVG file to export.
 +==Gerber to DXF (This one failed with 45 degree rounded-end pads. gerbv totally screwed up the export)==
 Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/KiCAD) and your laser takes DXF and I can't find a free Gerber to DXF converter.  What do I do? Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/KiCAD) and your laser takes DXF and I can't find a free Gerber to DXF converter.  What do I do?
smtstencil.txt · Last modified: 2020/11/04 18:02 by swalde
