smtstencil [2015/11/24 01:04] – srw7 | smtstencil [2020/11/04 17:42] – swalde | ||
Line 36: | Line 36: | ||
- set velocity to 800 (it will go as fast as it can) and power to 30% | - set velocity to 800 (it will go as fast as it can) and power to 30% | ||
- carve out | - carve out | ||
+ | ==Gerber to DXF (New, even more complicated workflow)== | ||
+ | Okay, but I have a Gerber file (that someone gave me, so, no, I can't re-export from Eagle/ | ||
+ | Simple! | ||
+ | - Open the GTP file in Gerbv | ||
+ | - Export as PNG, 1016 dpi (this is arbitrary and is a leftover from a previous attempted workflow) | ||
+ | - Load PNG into GIMP | ||
+ | - Set DPI in Image-> | ||
+ | - Colour-> | ||
+ | - Colour-> | ||
+ | - Select-> | ||
+ | - Select-> | ||
+ | - New Layer, white background | ||
+ | - Fill (whole selection) with black | ||
+ | - delete original layer | ||
+ | - Export as PNG | ||
+ | - Load PNG into Inkscape | ||
+ | - Trace Bitmap | ||
+ | - delete bitmap | ||
+ | - Note dimensions in mm | ||
+ | - save as DXF | ||
+ | - Load into Smartcarve | ||
+ | - Set the dimensions | ||
+ | - New possible process from here? (avoids having to " | ||
+ | - In The Gimp, choose Selection-> | ||
+ | - Open the paths dock. Right-click on the path and choose " | ||
+ | - Name the SVG file to export. | ||
+ | ==Gerber to DXF (This one failed with 45 degree rounded-end pads. gerbv totally screwed up the export)== | ||
+ | Simple! | ||
+ | I did this all on Linux, so if things work different on Windows, please let me know. | ||
+ | Use **gerbv** to open the gerber file. Look at it. Use the Measure tool to measure some easy-to-repeat dimension. | ||
+ | Open that SVG file in **Inkscape**. | ||
+ | Now, open that DXF in **LibreCAD**. (This step might not be necessary, but follow along for now.) Remember that dimension I asked you to measure? | ||
