laser_cutter [2019/01/25 00:02] – [Material Settings] swaldelaser_cutter [2021/07/10 04:21] (current) – [Material Settings] reveng
-==== Large Laser Cutter ==== +==== Laser Cutter ====
-NoteWe have two laser cutters now This page is for the big one!+
 +==== Getting Started Manual ====
 +[[https://sktechworks.ca/wp-content/uploads/2019/11/FrankenLaser-1.pdf|Quick Reference Guide]]
 ==== Inkscape ==== ==== Inkscape ====
Line 8: Line 10:
 | Plywood   | 1/8"       | 35%   |<del>40mm/s</del> 30-35mm/ | Use masking to prevent charring | | Plywood   | 1/8"       | 35%   |<del>40mm/s</del> 30-35mm/ | Use masking to prevent charring |
Line 18: Line 20:
 | PET-G | .020"       | 100%   | 75mm/  | | | PET-G | .020"       | 100%   | 75mm/  | |
-| ABS | 1/8" - 3mm | 100% | 18mm/s  | This previously said 20mm/s @75% but that wasn'cutting through |+| ABS | 1/8" - 3mm | 100% | 11mm/s  | ** Tested on new tube ** Used to say 18, but that wouldn'cut through. Third tube is running better, now.  Maybe back to 18?|
Line 34: Line 36:
-Sometimes you can't easily raise your work.  You might be dealing with warped stock which is difficult to both raise and pull flat (see below), or cutting tightly-spaced parts that risk falling "under" future cut lines when they come loose from the stock.  In these cases, masking the back of your work is a good idea.  Regular or painters masking tape can work, but is tedious to apply in narrow strips and can release harmful fumes when cut through.  A better option is to use paper transfer tape from a sign making supply shop.  The material is just paper, which is safe to cut.  These tapes come in rolls up to 24 inches wide and 100 feet long.  Most supply shops can slice the rolls into narrower dimensions for free if you ask.  Crossman Graphic Supply (now TG Graphics) is a good Saskatoon source for this.  They currently (March 2015) have discounted rolls of low-tack transfer tape available - this tape is becoming useless for vinyl signmakers, because most vinyl has more powerful adhesive on it, making the tape not usable for transfers.  But low-tack is exactly what you want for laser masking, because it won't wreck your work when peeling it off, and there's minimal adhesive to burn through and cause smoke.+Sometimes you can't easily raise your work.  You might be dealing with warped stock which is difficult to both raise and pull flat (see below), or cutting tightly-spaced parts that risk falling "under" future cut lines when they come loose from the stock.  In these cases, masking the back of your work is a good idea.  Regular or painters masking tape can work, but is tedious to apply in narrow strips and can release harmful fumes when cut through.  A better option is to use paper transfer tape from a sign making supply shop.  The material is just paper, which is safe to cut.  These tapes come in rolls up to 24 inches wide and 100 feet long.  Most supply shops can slice the rolls into narrower dimensions for free if you ask.  Crossman Graphic Supply (now TG Graphics) is a good Saskatoon source for this.  They currently (March 2015) have discounted rolls of low-tack transfer tape available - this tape is becoming useless for vinyl signmakers, because most vinyl has more powerful adhesive on it, making the tape not usable for transfers.  But low-tack is exactly what you want for laser masking, because it won't wreck your work when peeling it off, and there's minimal adhesive to burn through and cause smoke. Please **do not** use the masking tape on the wall in the shop. Masking cuts requires a lot of tape. Please purchase your own.
 | Stainless Steel | 100% | 25mm/s to 50mm/s | | Stainless Steel | 100% | 25mm/s to 50mm/s |
