inventory [2019/12/29 22:16] – swalde | inventory [2022/04/18 04:06] – braeden.leislar | ||
- | 3D Printers: | + | ====3D Printers:==== |
- | * Solidoodle 3 with 20cm x 20cm x 20cm print area and heated bed, configured for ABS. | + | * [[Makerbot|MakerBot Replicator 2]] |
- | * MakerBot Replicator 2 with 28cm x 15cm x 15cm print area, configured | + | * [[Resin Printer|Anycubic Photon S (SLA Resin Printer)]] |
+ | * <del>Solidoodle 3 with 20cm x 20cm x 20cm print area and heated bed, configured for ABS. (down for rebuild)</ | ||
- | Laser Cutter: | + | ====Laser Cutter:==== |
- | * Ruida controller with 1300mm x 1000mm | + | * Ruida controller with 1300mm x 1020mm |
- | Electronics bench: | + | ====Electronics bench:==== |
* Aouye soldering station with adjustable iron and hot air rework gun. | * Aouye soldering station with adjustable iron and hot air rework gun. | ||
* Adjustable Weller soldering station. | * Adjustable Weller soldering station. | ||
Line 15: | Line 16: | ||
* plus a variety of multimeters, | * plus a variety of multimeters, | ||
* Spacebox is a reasonably current computer available for use by members and is used for a variety of things including CAD, CAM, embedded programming, | * Spacebox is a reasonably current computer available for use by members and is used for a variety of things including CAD, CAM, embedded programming, | ||
* There are also several laptops with Windows 7 and Windows 10 that are available for members' | * There are also several laptops with Windows 7 and Windows 10 that are available for members' | ||
- | Hand tools: | + | ====Hand tools:==== |
* screwdrivers | * screwdrivers | ||
* pliers | * pliers | ||
Line 33: | Line 34: | ||
* and more | * and more | ||
- | In our "Dirty Room": | + | ====In our "Dirty Room":==== |
* OMIO X6-2200l CNC router. (Can cut aluminium) | * OMIO X6-2200l CNC router. (Can cut aluminium) |
