inventory [2019/01/25 03:47] – swalde | inventory [2022/04/25 03:42] – swalde | ||
- | 3D Printers: | + | ====3D Printers:==== |
- | * Solidoodle 3 with 20cm x 20cm x 20cm print area and heated bed, configured for ABS. | + | * [[Makerbot|MakerBot Replicator 2]] |
- | * MakerBot Replicator 2 with 28cm x 15cm x 15cm print area, configured | + | * [[Ender3v2|Ender 3 V2]] |
+ | * [[Resin Printer|Anycubic Photon S (SLA Resin Printer)]] | ||
+ | * <del>Solidoodle 3 with 20cm x 20cm x 20cm print area and heated bed, configured for ABS. (down for rebuild)</ | ||
- | Laser Cutter: | + | ====Laser Cutter:==== |
- | * Large cutter | + | * Ruida controller |
- | Electronics bench: | + | ====Electronics bench:==== |
* Aouye soldering station with adjustable iron and hot air rework gun. | * Aouye soldering station with adjustable iron and hot air rework gun. | ||
* Adjustable Weller soldering station. | * Adjustable Weller soldering station. | ||
* Fixed temperature Weller soldering station. | * Fixed temperature Weller soldering station. | ||
* Korad dual power supply 0-30V 0-3A | * Korad dual power supply 0-30V 0-3A | ||
- | * MPJA Single power supply 0-30V 0-3A | ||
* Atten digital oscilloscope | * Atten digital oscilloscope | ||
* Toaster oven modified for reflow soldering. (with profile controller) | * Toaster oven modified for reflow soldering. (with profile controller) | ||
* plus a variety of multimeters, | * plus a variety of multimeters, | ||
* Spacebox is a reasonably current computer available for use by members and is used for a variety of things including CAD, CAM, embedded programming, | * Spacebox is a reasonably current computer available for use by members and is used for a variety of things including CAD, CAM, embedded programming, | ||
* There are also several laptops with Windows 7 and Windows 10 that are available for members' | * There are also several laptops with Windows 7 and Windows 10 that are available for members' | ||
- | Hand tools: | + | ====Hand tools:==== |
* screwdrivers | * screwdrivers | ||
* pliers | * pliers | ||
Line 34: | Line 35: | ||
* and more | * and more | ||
- | In our "Dirty Room": | + | ====In our "Dirty Room":==== |
+ | * OMIO X6-2200l CNC router. (Can cut aluminium) | ||
* large bandsaw with wood blade | * large bandsaw with wood blade | ||
* small bandsaw with metal blade | * small bandsaw with metal blade | ||
Line 47: | Line 49: | ||
* dremel tools | * dremel tools | ||
* miter saw | * miter saw | ||
- | * table saw | + | * table saw (Upgraded December 2019) |
* skilsaw | * skilsaw | ||
* more hand tools | * more hand tools |
