inventory [2016/07/07 02:52] – srw7 | inventory [2022/04/18 04:06] – braeden.leislar | ||
- | NOTE: This page was so terribly out of date. | + | ====3D Printers:==== |
+ | * [[Makerbot|MakerBot Replicator 2]] | ||
+ | * [[Resin Printer|Anycubic Photon S (SLA Resin Printer)]] | ||
+ | ====Laser Cutter: | ||
+ | * Ruida controller with 1300mm x 1020mm bed and 130W tube. | ||
+ | ====Electronics bench: | ||
+ | * Aouye soldering station with adjustable iron and hot air rework gun. | ||
+ | * Adjustable Weller soldering station. | ||
+ | * Fixed temperature Weller soldering station. | ||
+ | * Korad dual power supply 0-30V 0-3A | ||
+ | * Atten digital oscilloscope | ||
+ | * Toaster oven modified for reflow soldering. (with profile controller) | ||
+ | * plus a variety | ||
+ | * Spacebox is a reasonably current computer available for use by members and is used for a variety of things including CAD, CAM, embedded programming, | ||
+ | * There are also several laptops with Windows 7 and Windows 10 that are available for members' | ||
+ | ====Hand tools: | ||
+ | * screwdrivers | ||
+ | * pliers | ||
+ | * wrenches | ||
+ | * crimpers | ||
+ | * wire cutters / strippers | ||
+ | * files | ||
+ | * nibbler | ||
+ | * squares | ||
+ | * levels | ||
+ | * hammers | ||
+ | * brushes | ||
+ | * and more | ||
+ | ====In our "Dirty Room": | ||
+ | * OMIO X6-2200l CNC router. (Can cut aluminium) | ||
+ | * large bandsaw with wood blade | ||
+ | * small bandsaw with metal blade | ||
+ | * large drill press | ||
+ | * small drill press | ||
+ | * bench grinder | ||
+ | * scroll saw | ||
+ | * small bench sander | ||
+ | * cordless drills | ||
+ | * jigsaw | ||
+ | * dremel tools | ||
+ | * miter saw | ||
+ | * table saw (Upgraded December 2019) | ||
+ | * skilsaw | ||
+ | * more hand tools | ||
+ | * 12" x 36" metal lathe (requires special training) | ||
+ | In the Library: | ||
+ | * there are a surprising variety of books available on topics ranging from beginner electronics to advanced materials science. | ||
===== Inventory ===== | ===== Inventory ===== |
