cnc_machine_goliath [2018/09/06 17:56] – thesaxmachine | cnc_machine_goliath [2022/07/17 03:21] – swalde | ||
+ | === Note: Goliath is no longer at the space. | ||
=== CNC Training === | === CNC Training === | ||
Line 14: | Line 16: | ||
* turn off the switch for that | * turn off the switch for that | ||
* turn off the switch for cnc power | * turn off the switch for cnc power | ||
- | * notify | + | * notify |
* Be aware of all the different ways you can shut off the machine | * Be aware of all the different ways you can shut off the machine | ||
* Safety should be your number one concern | * Safety should be your number one concern | ||
Line 158: | Line 160: | ||
==Fusion 360 Toolpaths== | ==Fusion 360 Toolpaths== | ||
+ | I nice formatted tutorial of how to setup a job in Fusion 360 | ||
+ | [[http:// | ||
Update: the following G28 thing might actually not be necessary. | Update: the following G28 thing might actually not be necessary. | ||
