cnc_machine_goliath [2016/02/19 15:49] – Created cnc training page thesaxmachinecnc_machine_goliath [2022/07/17 03:23] (current) swalde
 +=== Note: Goliath is no longer at the space.  The Laguna is a more capable replacement ===
 +[[laguna|Laguna]]
 === CNC Training === === CNC Training ===
Line 8: Line 11:
   * Hair tied back and out of the way   * Hair tied back and out of the way
   * If you notice anything strange with the machine DO NOT USE IT   * If you notice anything strange with the machine DO NOT USE IT
-    * Notify Albert+    * Notify thespace@sktechworks.ca
   * Be aware of where the big red button is   * Be aware of where the big red button is
     * Pushing the button will stop the current job from processing      * Pushing the button will stop the current job from processing
Line 14: Line 17:
     * turn off the switch for that     * turn off the switch for that
     * turn off the switch for cnc power     * turn off the switch for cnc power
-    * notify Albert+    * notify thespace@sktechworks.ca
   * Be aware of all the different ways you can shut off the machine   * Be aware of all the different ways you can shut off the machine
     * Safety should be your number one concern     * Safety should be your number one concern
Line 157: Line 160:
       * so we might as well use it       * so we might as well use it
 +==Fusion 360 Toolpaths==
 +I nice formatted tutorial of how to setup a job in Fusion 360
 +[[http://evanandkatelyn.com/2018/01/fusion-360-cam-tutorial-for-cnc-beginners/]]
 +{{:Techworks.zip| Fusion 360 Post Processor}}
 +Update: the following G28 thing might actually not be necessary.  Before setting the origin on the workpiece, move the spindle to a safe location above the workpiece.  Then, click "Ref All Home."  If you do this, that location will be the "Home" position that G28 goes to.
 +This is very, very preliminary, but critical:
 +DISABLE G28.  If you leave G28 enabled, the machine will rapid to a bad place.  If you are lucky, it will only break your bit.  If you are not lucky, you will break the machine.  This has already happened once.
 +DISABLE M6.  I'm not sure if this actually causes problems, but we don't have a toolchanger, so telling the machine to pick up a tool is pointless.
 +==Feeds and Speeds Resources==
 +Onsrud has some good charts for chipload of various materials.
 + [[http://www.onsrud.com/xdoc/feedspeeds]]
 +Once you know your chipload range, there are lots of online calculators to help you calculate RPM and feedrate.
 + [[http://www.monstertool.com/monster_tool_calculators.html]]
cnc_machine_goliath.txt · Last modified: 2022/07/17 03:23 by swalde
