stratum1ntp [2021/10/22 20:11] andrewstratum1ntp [2021/11/28 02:51] (current) andrew
Line 11: Line 11:
 +dtoverlay=pi3-disable-wifi
Line 150: Line 151:
 apt -y autoremove apt -y autoremove
 apt clean apt clean
 +</code>
 +    * <code>crontab -e
 </code> </code>
stratum1ntp.1634933480.txt.gz · Last modified: by andrew
