stratum1ntp [2019/08/21 20:04] andrewstratum1ntp [2021/11/28 02:51] (current) andrew
 ====== Stratum 1 NTP Setup on Raspberry Pi ====== ====== Stratum 1 NTP Setup on Raspberry Pi ======
-=== By: Bun-Bun & guppy ===+== By: Bun-Bun & guppy ==
Line 11: Line 11:
 +dtoverlay=pi3-disable-wifi
Line 139: Line 140:
   * https://www.ntpsec.org/white-papers/stratum-1-microserver-howto/   * https://www.ntpsec.org/white-papers/stratum-1-microserver-howto/
-  * Add nohz=off to the end of the line in /etc/cmdline.txt+  * Add nohz=off to the end of the line in /boot/cmdline.txt
   * configure system to run cpu full speed   * configure system to run cpu full speed
     * <code>apt -y install cpufrequtils     * <code>apt -y install cpufrequtils
Line 150: Line 151:
 apt -y autoremove apt -y autoremove
 apt clean apt clean
 +</code>
 +    * <code>crontab -e
 </code> </code>
stratum1ntp.1566417867.txt.gz · Last modified: by andrew
