stratum1ntp [2019/08/21 19:39] andrewstratum1ntp [2021/11/28 02:51] (current) andrew
 ====== Stratum 1 NTP Setup on Raspberry Pi ====== ====== Stratum 1 NTP Setup on Raspberry Pi ======
 +== By: Bun-Bun & guppy ==
   * Setup rpi with latest Raspbian, enable ssh, etc...   * Setup rpi with latest Raspbian, enable ssh, etc...
Line 9: Line 11:
 +dtoverlay=pi3-disable-wifi
Line 137: Line 140:
   * https://www.ntpsec.org/white-papers/stratum-1-microserver-howto/   * https://www.ntpsec.org/white-papers/stratum-1-microserver-howto/
-  * Add nohz=off to the end of the line in /etc/cmdline.txt+  * Add nohz=off to the end of the line in /boot/cmdline.txt
   * configure system to run cpu full speed   * configure system to run cpu full speed
     * <code>apt -y install cpufrequtils     * <code>apt -y install cpufrequtils
Line 143: Line 146:
 systemctl restart cpufrequtils</code> systemctl restart cpufrequtils</code>
   * Remove useless stuff   * Remove useless stuff
-    * <code>apt -y purge bluez triggerhappy +    * <code>apt -y purge bluez triggerhappy wpasupplicant alsa-utils
-apt -y purge wpasupplicant +systemctl stop avahi-daemon
-apt -y purge alsa-utils +systemctl disable avahi-daemon
-systemctl stop raspbian avahi-daemon +
-systemctl disable raspbian avahi-daemon+
 apt -y autoremove apt -y autoremove
 apt clean apt clean
 +</code>
 +    * <code>crontab -e
 </code> </code>
stratum1ntp.1566416384.txt.gz · Last modified: by andrew
