Next revisionBoth sides next revision | |||
soapmaking [2013/05/21 05:45] – created srw7 | soapmaking [2013/05/21 05:49] – srw7 | ||
Line 2: | Line 2: | ||
- | More instructions | + | Basic Recipe:\\ |
+ | Oil\\ | ||
+ | Water\\ | ||
+ | Lye (Sodium Hydroxide)\\ | ||
+ | Carefully weigh Oil. \\ | ||
+ | Multiply by SAP to determine amount of lye. (Make sure to use NaOH values, not KOH.)\\ | ||
+ | Use 2.7g of water per 1g of lye.\\ | ||
+ | Discount lye for superfat.\\ | ||
+ | Discount water as desired.\\ | ||
+ | Slowly add lye to water. | ||
+ | *** NEVER add water to lye ***\\ | ||
+ | Slowly add lye solution to oil, stirring constantly until trace.\\ | ||
+ | Pour mixture into mold and allow to partially harden. (24h)\\ | ||
+ | Cut into bars. Allow to cure for 4 to 6 weeks.\\ | ||
+ | More involved order of ingredients: | ||
+ | Lye solution: | ||
+ | 1. Water\\ | ||
+ | 2. Sugar (for clear soap)\\ | ||
+ | 3. Salt\\ | ||
+ | 4. Ammonia\\ | ||
+ | 5. Borax\\ | ||
+ | 6. Lye\\ | ||
+ | Oils:\\ | ||
+ | 1. Melt any solid oils/ | ||
+ | 2. Keep “superfats” seperate.\\ | ||
+ | Start mixing.\\ | ||
+ | 1. Lanolin (Max 120F, otherwise it will curdle)\\ | ||
+ | 2. Coal Oil\\ | ||
+ | 3. Lemon Juice\\ | ||
+ | Mix until trace.\\ | ||
+ | 1. Add ground oatmeal or spent coffee grounds\\ | ||
+ | 2. Vitamin E\\ | ||
+ | 3. Colouring dyes\\ | ||
+ | 4. Superfatting oils\\ | ||
+ | 5. Scenting oils\\ |
