small_laser_cutter [2017/01/15 03:51] – srw7 | small_laser_cutter [2018/07/04 03:19] (current) – [Material Settings] swalde | ||
+ | ==== Focus ==== | ||
+ | The documentation doesn' | ||
+ | ==== Power ==== | ||
+ | Unlike the big laser, the power setting must be manually adjusted on the control panel. | ||
==== Material Settings ==== | ==== Material Settings ==== | ||
Please consider the following settings as guidelines only, it's always a good idea to do a test cut first. | Please consider the following settings as guidelines only, it's always a good idea to do a test cut first. | ||
Line 7: | Line 13: | ||
| Plywood | | Plywood | ||
| MDF | 1/ | | MDF | 1/ | ||
- | | MDF | 1/ | + | | MDF | 1/ |
+ | | Acrylic | ||
=== Etching === | === Etching === | ||
Line 13: | Line 20: | ||
| MDF/ | | MDF/ | ||
+ | | LaserMAX | 17% | 500mm/s | | ||
+ | | CerMark LMM-6000 on Aluminum | 100% | 125-250mm/s | | ||
+ | Haven' |
