Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision |
laser_cutter [2019/09/09 23:37] – swalde | laser_cutter [2021/07/10 03:53] – [Material Settings] RevEng |
==== Laser Cutter ==== | ==== Laser Cutter ==== |
| ==== Getting Started Manual ==== |
| [[https://sktechworks.ca/wp-content/uploads/2019/11/FrankenLaser-1.pdf|Quick Reference Guide]] |
==== Inkscape ==== | ==== Inkscape ==== |
Please consider the following settings as guidelines only, it's always a good idea to do a test cut first. | Please consider the following settings as guidelines only, it's always a good idea to do a test cut first. |
=== Through Cuts === | === Through Cuts (with 150W Laser 2) === |
^ Material ^ Thickness ^ Power ^ Speed ^ Notes ^ | ^ Material ^ Thickness ^ Power ^ Speed ^ Notes ^ |
| Plywood | 1/8" | 35% |<del>40mm/s</del> 30-35mm/s | Use masking to prevent charring | | | Plywood | 1/8" | 35% |<del>40mm/s</del> 30-35mm/s | Use masking to prevent charring | |
| PET-G | .020" | 100% | 75mm/s | | | | PET-G | .020" | 100% | 75mm/s | | |
| Acrylic | 1/8" - 3mm | 100% | 20mm/s | | | | Acrylic | 1/8" - 3mm | 100% | 20mm/s | | |
| ABS | 1/8" - 3mm | 100% | 11mm/s | *** Tested on new tube *** | | | ABS | 1/8" - 3mm | 100% | 11mm/s | ** Tested on new tube ** Used to say 18, but that wouldn't cut through. Third tube is running better, now. Maybe back to 18?| |
| Felt | 1/16" | 10% | 20mm/s | Use backing board | | | Felt | 1/16" | 10% | 20mm/s | Use backing board | |
| Styrene | 0.30" | 100% | 20mm/s | | | | Styrene | 0.30" | 100% | 20mm/s | | |
=== Masking your work with paper transfer tape === | === Masking your work with paper transfer tape === |
Sometimes you can't easily raise your work. You might be dealing with warped stock which is difficult to both raise and pull flat (see below), or cutting tightly-spaced parts that risk falling "under" future cut lines when they come loose from the stock. In these cases, masking the back of your work is a good idea. Regular or painters masking tape can work, but is tedious to apply in narrow strips and can release harmful fumes when cut through. A better option is to use paper transfer tape from a sign making supply shop. The material is just paper, which is safe to cut. These tapes come in rolls up to 24 inches wide and 100 feet long. Most supply shops can slice the rolls into narrower dimensions for free if you ask. Crossman Graphic Supply (now TG Graphics) is a good Saskatoon source for this. They currently (March 2015) have discounted rolls of low-tack transfer tape available - this tape is becoming useless for vinyl signmakers, because most vinyl has more powerful adhesive on it, making the tape not usable for transfers. But low-tack is exactly what you want for laser masking, because it won't wreck your work when peeling it off, and there's minimal adhesive to burn through and cause smoke. | Sometimes you can't easily raise your work. You might be dealing with warped stock which is difficult to both raise and pull flat (see below), or cutting tightly-spaced parts that risk falling "under" future cut lines when they come loose from the stock. In these cases, masking the back of your work is a good idea. Regular or painters masking tape can work, but is tedious to apply in narrow strips and can release harmful fumes when cut through. A better option is to use paper transfer tape from a sign making supply shop. The material is just paper, which is safe to cut. These tapes come in rolls up to 24 inches wide and 100 feet long. Most supply shops can slice the rolls into narrower dimensions for free if you ask. Crossman Graphic Supply (now TG Graphics) is a good Saskatoon source for this. They currently (March 2015) have discounted rolls of low-tack transfer tape available - this tape is becoming useless for vinyl signmakers, because most vinyl has more powerful adhesive on it, making the tape not usable for transfers. But low-tack is exactly what you want for laser masking, because it won't wreck your work when peeling it off, and there's minimal adhesive to burn through and cause smoke. Please **do not** use the masking tape on the wall in the shop. Masking cuts requires a lot of tape. Please purchase your own. |
=== Holding down thin, warped material === | === Holding down thin, warped material === |
If you've ever cut 1/8" plywood, you'll know that warped stock is pretty much inescapable, and it can be difficult to lay your piece down flat on the bed. Even a couple mm of variation can take the laser from being perfectly focused to being a total mess. There are some heavy white metal bars laying on top of the machine. These work to a degree, but get in the way of the laser head sometimes, depending on the cut you're doing and how much warp you're trying to flatten. | If you've ever cut 1/8" plywood, you'll know that warped stock is pretty much inescapable, and it can be difficult to lay your piece down flat on the bed. Even a couple mm of variation can take the laser from being perfectly focused to being a total mess. There are some heavy white metal bars laying on top of the machine. These work to a degree, but get in the way of the laser head sometimes, depending on the cut you're doing and how much warp you're trying to flatten. |
An excellent alternative is to use rare earth/neodymium magnets directly on top of your material. A 1" magnet with 30lbs of pull (sorry for lack of metric) will easily flatten out a region of think plywood or curved cardstock, etc. The advantage is that the laser head will pass right over it, unlike the bars, so you can set them right in the middle of your sheet, instead of just on the edges. Make sure you put them in an area that isn't going to be cut - measure from your origin on both the cutter bed and your SmartCarve drawing to where you plan to drop a magnet, just to be sure you aren't on top of a cut line | An excellent alternative is to use rare earth/neodymium magnets directly on top of your material. A 1" magnet with 30lbs of pull (sorry for lack of metric) will easily flatten out a region of think plywood or curved cardstock, etc. The advantage is that the laser head will pass right over it, unlike the bars, so you can set them right in the middle of your sheet, instead of just on the edges. Make sure you put them in an area that isn't going to be cut - measure from your origin on both the cutter bed and your drawing to where you plan to drop a magnet, just to be sure you don't try to cut over a magnet. |
=== Etching === | === Rastering (with 40W Laser 1) === |
| ^ Material ^ Power ^ Speed ^ Interval ^ |
| | Plywood | 90% | 200mm/s | 0.1mm | |
| | Acrylic | 90% | 200mm/s | 0.1mm | |
| Remove any surface covering (e.g. plastic film, masking tape). Focus with 11.5mm from tip of nozzle to surface of material. Adjust valve on air line so that you can't feel air coming out of nozzle tip unless you completely cover it with your finger tip. |
| === Etching (with 40W Laser 1) === |
| ^ Material ^ Max Power ^ Min Power ^ Speed ^ |
| | Plywood | 50% | 10% | 100mm/s | |
| | Acrylic | 50% | 10% | 100mm/s | |
| === Etching (with 150W Laser 2) === |
^ Material ^ Power ^ Speed ^ | ^ Material ^ Power ^ Speed ^ |
| Plywood | 5% - 10% | 100mm/s to 200mm/s | | | Plywood | 5% - 10% [1] | 100mm/s to 200mm/s | |
| Acrylic |5% - 10% | 100mm/s to 500mm/s | | | Acrylic |5% - 10% [1] | 100mm/s to 500mm/s | |
| Leather |5% - 15% | 200mm/s to 500mm/s | | | Leather |5% - 15% [1] | 200mm/s to 500mm/s | |
| Stainless Steel | 100% | 25mm/s to 50mm/s | | | Stainless Steel | 100% | 25mm/s to 50mm/s | |
| | PCB Solder Mask | 14.5% [1] | 200mm/s | |
| [1] Note that lines will tend to overcut at corners and ends. Consider using the 40W laser for finer lines and more consistent power. |
| Focus with 6mm from tip of nozzle to surface of material. |
=== Transparencies === | === Transparencies === |
