laser_cutter [2019/01/25 00:02] – [Material Settings] swalde | laser_cutter [2019/09/09 23:37] – swalde | ||
- | ==== Large Laser Cutter ==== | + | ==== Laser Cutter ==== |
- | Note: We have two laser cutters now. This page is for the big one! | + | |
==== Inkscape ==== | ==== Inkscape ==== | ||
Line 18: | Line 17: | ||
| PET-G | .020" | | PET-G | .020" | ||
- | | ABS | 1/8" - 3mm | 100% | 18mm/s | This previously said 20mm/s @75% but that wasn't cutting through | + | | ABS | 1/8" - 3mm | 100% | 11mm/s | *** Tested on new tube *** | |
| Styrene | 0.30" | 100% | 20mm/ | | Styrene | 0.30" | 100% | 20mm/ |
