laser_cutter [2017/01/15 03:40] srw7laser_cutter [2021/07/10 04:21] (current) – [Material Settings] reveng
-==== Large Laser Cutter ==== +==== Laser Cutter ====
-NoteWe have two laser cutters now This page is for the big one!+
 +==== Getting Started Manual ====
 +[[https://sktechworks.ca/wp-content/uploads/2019/11/FrankenLaser-1.pdf|Quick Reference Guide]]
 +==== Inkscape ====
 +[[https://www.ponoko.com/blog/how-to-make/inkscape-vector-tutorials/?utm_source=Ponoko+Newsletter&utm_campaign=83985f5700-EMAIL_CAMPAIGN_2017_11_14&utm_medium=email&utm_term=0_218f094e4f-83985f5700-38954136|Vector tutorials]]
 ==== Material Settings ==== ==== Material Settings ====
-| Plywood   | 1/8"       | 35%   | 40mm/ | Use masking to prevent charring | +| Plywood   | 1/8"       | 35%   |<del>40mm/s</del> 30-35mm/s  | Use masking to prevent charring |
-| Plywood   | 1/4"       | 100%   | 15mm/ | | +| Plywood   | 1/4"       | 100%   |<del>15mm/s</del> 10-15mm/ | |
-| MDF   | 1/8"       100%   20mm/s  | |+| MDF   | 1/8"       35%   40mm/s  | |
 | MDF   | 1/4"       | 100%   | 5mm/s  | | | MDF   | 1/4"       | 100%   | 5mm/s  | |
 +| Hardboard | 1/8" | 100% | 40mm/s | |
 | PET-G | 1/8"       | 100%   | 1 pass at first 25mm/s then 50mm/s*  | | | PET-G | 1/8"       | 100%   | 1 pass at first 25mm/s then 50mm/s*  | |
 +| PET-G | .020"       | 100%   | 75mm/  | |
-| ABS | 1/8" - 3mm | 100% | 20mm/s  | |+| ABS | 1/8" - 3mm | 100% | 11mm/s  | ** Tested on new tube ** Used to say 18, but that wouldn't cut through. Third tube is running better, now.  Maybe back to 18?|
-| Acetate Film (Transparencies)| |10-15%|50mm/s| +| Acetate Film (Transparencies)| |10-15%|50mm/s
-| Paper/Heavy Paper | -- | 5% | 50mm/s| +| Paper/Heavy Paper | -- | 5% | 50mm/s
-| Bristol Board | -- | 20% | 50mm/s|+| Bristol Board | -- | 20% | 50mm/s| |
 +| Compact Disc | -- | 15% | 25mm/s| |
 +| EVA Foam | 1/2" | 100% | 40mm/s | 50mm/s almost got through, but not quite|
 +| EVA Foam | "Hobby Foam" maybe 2mm? | 100% | 80mm/s | This may have been way overkill, but it was my first attempt and it worked fine but scorched the bottom a bit. |
 * Make sure the first pass cuts through or there will be too much smoke. The second pass is necessary because the plastic melts itself back together during the first pass. * Make sure the first pass cuts through or there will be too much smoke. The second pass is necessary because the plastic melts itself back together during the first pass.
Line 26: Line 36:
-Sometimes you can't easily raise your work.  You might be dealing with warped stock which is difficult to both raise and pull flat (see below), or cutting tightly-spaced parts that risk falling "under" future cut lines when they come loose from the stock.  In these cases, masking the back of your work is a good idea.  Regular or painters masking tape can work, but is tedious to apply in narrow strips and can release harmful fumes when cut through.  A better option is to use paper transfer tape from a sign making supply shop.  The material is just paper, which is safe to cut.  These tapes come in rolls up to 24 inches wide and 100 feet long.  Most supply shops can slice the rolls into narrower dimensions for free if you ask.  Crossman Graphic Supply (now TG Graphics) is a good Saskatoon source for this.  They currently (March 2015) have discounted rolls of low-tack transfer tape available - this tape is becoming useless for vinyl signmakers, because most vinyl has more powerful adhesive on it, making the tape not usable for transfers.  But low-tack is exactly what you want for laser masking, because it won't wreck your work when peeling it off, and there's minimal adhesive to burn through and cause smoke.+Sometimes you can't easily raise your work.  You might be dealing with warped stock which is difficult to both raise and pull flat (see below), or cutting tightly-spaced parts that risk falling "under" future cut lines when they come loose from the stock.  In these cases, masking the back of your work is a good idea.  Regular or painters masking tape can work, but is tedious to apply in narrow strips and can release harmful fumes when cut through.  A better option is to use paper transfer tape from a sign making supply shop.  The material is just paper, which is safe to cut.  These tapes come in rolls up to 24 inches wide and 100 feet long.  Most supply shops can slice the rolls into narrower dimensions for free if you ask.  Crossman Graphic Supply (now TG Graphics) is a good Saskatoon source for this.  They currently (March 2015) have discounted rolls of low-tack transfer tape available - this tape is becoming useless for vinyl signmakers, because most vinyl has more powerful adhesive on it, making the tape not usable for transfers.  But low-tack is exactly what you want for laser masking, because it won't wreck your work when peeling it off, and there's minimal adhesive to burn through and cause smoke. Please **do not** use the masking tape on the wall in the shop. Masking cuts requires a lot of tape. Please purchase your own.
 +| Stainless Steel | 100% | 25mm/s to 50mm/s |
 ^ Method  ^ Power  ^ Speed ^ Notes ^ ^ Method  ^ Power  ^ Speed ^ Notes ^
 | Raster | 1% | 40mm/s | [[smtstencil|Detailed SMT Stencil Instructions]]| | Raster | 1% | 40mm/s | [[smtstencil|Detailed SMT Stencil Instructions]]|
 +=== Laserable Materials ===
 +This chart was stolen from Epilog, maker of lasers that are more expensive than ours.  However, still being CO2 lasers, one can assume the list of compatible materials should be the same.
 +^ Material ^ Engrave ^ Cut ^
 +| Wood | x | x |
 +| Acrylic | x | x |
 +| Fabric | x | x |
 +| Glass | x | |
 +| Coated Metals | x | |
 +| Ceramic | x | |
 +| Delrin | x | x |
 +| Cloth | x | x |
 +| Leather | x | x |
 +| Marble | x | |
 +| Matte Board | x | x |
 +| Melamine | x | x |
 +| Paper | x | x |
 +| Mylar | x | x |
 +| Pressboard | x | x |
 +| Rubber | x | x |
 +| Wood Veneer | x | x |
 +| Fiberglass | x | x |
 +| Painted Metals | x | |
 +| Tile | x | |
 +| Cork | x | x |
 +| Corian | x | x |
 +| Anodized Aluminum | x | |
 +| Stainless Steel | x | |
 +| Titanium | x | |
