Next revisionBoth sides next revision
cnc_machine_goliath [2018/09/06 17:57] thesaxmachinecnc_machine_goliath [2018/09/06 18:06] thesaxmachine
Line 158: Line 158:
 ==Fusion 360 Toolpaths== ==Fusion 360 Toolpaths==
 +{{:Techworks.zip| Fusion 360 Post Processor}}
 Update: the following G28 thing might actually not be necessary.  Before setting the origin on the workpiece, move the spindle to a safe location above the workpiece.  Then, click "Ref All Home."  If you do this, that location will be the "Home" position that G28 goes to. Update: the following G28 thing might actually not be necessary.  Before setting the origin on the workpiece, move the spindle to a safe location above the workpiece.  Then, click "Ref All Home."  If you do this, that location will be the "Home" position that G28 goes to.
cnc_machine_goliath.txt · Last modified: 2022/07/17 03:23 by swalde
