cnc_machine_goliath [2017/10/19 20:39] – swalde | cnc_machine_goliath [2022/07/17 03:21] – swalde | ||
+ | === Note: Goliath is no longer at the space. | ||
=== CNC Training === | === CNC Training === | ||
Line 8: | Line 10: | ||
* Hair tied back and out of the way | * Hair tied back and out of the way | ||
* If you notice anything strange with the machine DO NOT USE IT | * If you notice anything strange with the machine DO NOT USE IT | ||
- | * Notify | + | * Notify |
* Be aware of where the big red button is | * Be aware of where the big red button is | ||
* Pushing the button will stop the current job from processing | * Pushing the button will stop the current job from processing | ||
Line 14: | Line 16: | ||
* turn off the switch for that | * turn off the switch for that | ||
* turn off the switch for cnc power | * turn off the switch for cnc power | ||
- | * notify | + | * notify |
* Be aware of all the different ways you can shut off the machine | * Be aware of all the different ways you can shut off the machine | ||
* Safety should be your number one concern | * Safety should be your number one concern | ||
Line 158: | Line 160: | ||
==Fusion 360 Toolpaths== | ==Fusion 360 Toolpaths== | ||
+ | I nice formatted tutorial of how to setup a job in Fusion 360 | ||
+ | [[http:// | ||
+ | Update: the following G28 thing might actually not be necessary. | ||
This is very, very preliminary, | This is very, very preliminary, | ||
DISABLE G28. If you leave G28 enabled, the machine will rapid to a bad place. | DISABLE G28. If you leave G28 enabled, the machine will rapid to a bad place. | ||
DISABLE M6. I'm not sure if this actually causes problems, but we don't have a toolchanger, | DISABLE M6. I'm not sure if this actually causes problems, but we don't have a toolchanger, | ||
+ | ==Feeds and Speeds Resources== | ||
+ | Onsrud has some good charts for chipload of various materials. | ||
+ | Once you know your chipload range, there are lots of online calculators to help you calculate RPM and feedrate. | ||
