bylaws [2013/03/13 17:04] – kaldonis | bylaws [2013/03/13 17:07] (current) – kaldonis | ||
==== Bylaws of Saskatoon TechWorks Inc ==== | ==== Bylaws of Saskatoon TechWorks Inc ==== | ||
=== Definitions and Interpretation === | === Definitions and Interpretation === | ||
Line 308: | Line 306: | ||
- A show of hands is used for voting by Members present at a meeting, except for elections or by request. | - A show of hands is used for voting by Members present at a meeting, except for elections or by request. | ||
- Various alternative voting methods available to the Members, including but not limited to electronic means, shall be determined on a per-vote basis by the Board and announced no less than three (3) days in advance of the vote. | - Various alternative voting methods available to the Members, including but not limited to electronic means, shall be determined on a per-vote basis by the Board and announced no less than three (3) days in advance of the vote. | ||
- | - If the vote is not scheduled in advance, arising instead naturally from proceedings at a meeting, the vote shall proceed, assuming quorum. Notice of such a vote in order for absent members to cast absentee votes, electronic or otherwise, is at the discretion of those | + | - If the vote is not scheduled in advance, arising instead naturally from proceedings at a meeting, the vote shall proceed, assuming quorum. Notice of such a vote in order for absent members to cast absentee votes, electronic or otherwise, is at the discretion of those in attendance, and failure to do so shall not invalidate the vote. This does not apply to issues that must be decided by Special Resolution. |
- | in attendance, and failure to do so shall not invalidate the vote. This does not apply to issues that must be decided by Special Resolution. | + | |
- In case of a dead-lock, the vote shall be requested a second time. If the second vote also results in a dead-lock, the Board will vote by Board majority to approve or deny the vote. If a minimum quorum of Board members is not available, the vote will be deferred until the next meeting. | - In case of a dead-lock, the vote shall be requested a second time. If the second vote also results in a dead-lock, the Board will vote by Board majority to approve or deny the vote. If a minimum quorum of Board members is not available, the vote will be deferred until the next meeting. | ||
- A majority of the votes of the Regular Members decides each issue and resolution, unless the issue needs to be decided by a Special Resolution. | - A majority of the votes of the Regular Members decides each issue and resolution, unless the issue needs to be decided by a Special Resolution. |
