small_laser_cutter [2017/01/15 05:49] srw7small_laser_cutter [2018/07/04 03:19] (current) – [Material Settings] swalde
Line 21: Line 21:
 | MDF/HB   | 10% - 20% | 500mm/ | | MDF/HB   | 10% - 20% | 500mm/ |
 | LaserMAX | 17% | 500mm/s | | LaserMAX | 17% | 500mm/s |
 +| CerMark LMM-6000 on Aluminum | 100% | 125-250mm/s |
 +Haven't dialed in the CerMark yet, but this will give you a starting point.
small_laser_cutter.txt · Last modified: by swalde
