inventory [2022/04/14 03:48] braeden.leislarinventory [2024/05/03 16:47] (current) swalde
-3D Printers: +====3D Printers:====
-  * [[Makerbot|MakerBot Replicator 2]]+  * [[Ender3v2|Ender 3 V2]]
   * [[Resin Printer|Anycubic Photon S (SLA Resin Printer)]]   * [[Resin Printer|Anycubic Photon S (SLA Resin Printer)]]
 +  * <del>[[Makerbot|MakerBot Replicator 2]]</del>
   * <del>Solidoodle 3 with 20cm x 20cm x 20cm print area and heated bed, configured for ABS. (down for rebuild)</del>   * <del>Solidoodle 3 with 20cm x 20cm x 20cm print area and heated bed, configured for ABS. (down for rebuild)</del>
-Laser Cutter:+====Laser Cutter:====
   * Ruida controller with 1300mm x 1020mm bed and 130W tube.   * Ruida controller with 1300mm x 1020mm bed and 130W tube.
-Electronics bench:+====Electronics bench:====
   * Aouye soldering station with adjustable iron and hot air rework gun.   * Aouye soldering station with adjustable iron and hot air rework gun.
   * Adjustable Weller soldering station.   * Adjustable Weller soldering station.
   * Fixed temperature Weller soldering station.   * Fixed temperature Weller soldering station.
-  * Korad dual power supply 0-30V 0-3A
-  * Atten digital oscilloscope
-  * Toaster oven modified for reflow soldering. (with profile controller)
   * plus a variety of multimeters, older oscilloscopes, function generators, a frequency counter, and hand tools.   * plus a variety of multimeters, older oscilloscopes, function generators, a frequency counter, and hand tools.
-"Community" computers:
-  * Spacebox is a reasonably current computer available for use by members and is used for a variety of things including CAD, CAM, embedded programming, and general internet use.
-  * There are also several laptops with Windows 7 and Windows 10 that are available for members' use for things such as Arduino programming and 3D model prep. (for the 3D printers)
-Hand tools:+====Hand tools:====
   * screwdrivers   * screwdrivers
   * pliers   * pliers
Line 34: Line 29:
   * and more   * and more
-In our "Dirty Room": +====In our "Wood Room":====
-  * "Goliath" our CNC router with approximately 20" x 40" bed. (Good for woods and plastics+  * "Laguna" our CNC router with approximately 48" x 48" bed. (Good for woods and plastics)
-  * OMIO X6-2200l CNC router. (Can cut aluminium)+
   * large bandsaw with wood blade   * large bandsaw with wood blade
-  * small bandsaw with metal blade+  * miter saw
 +  * table saw (Upgraded 2022)
 +  * scroll saw
 +====In our "Metal Room":====
 +  * OMIO X6-2200l CNC router. (Can cut aluminium)
   * large drill press   * large drill press
-  * small drill press
   * bench grinder   * bench grinder
-  * scroll saw
   * small bench sander   * small bench sander
   * cordless drills   * cordless drills
   * jigsaw   * jigsaw
   * dremel tools   * dremel tools
-  * miter saw
-  * table saw (Upgraded December 2019)
   * skilsaw   * skilsaw
   * more hand tools   * more hand tools
inventory.1649908107.txt.gz · Last modified: 2022/04/14 03:48 by braeden.leislar
