inventory [2020/11/28 18:06] – swalde | inventory [2024/05/03 16:47] (current) – swalde | ||
- | 3D Printers: | + | ====3D Printers:==== |
- | * MakerBot Replicator 2 with 28cm x 15cm x 15cm print area, configured for PLA. | + | * [[Ender3v2|Ender 3 V2]] |
- | * Prusa MK3S | + | * [[Resin Printer|Anycubic Photon S (SLA Resin Printer)]] |
- | * Anycubic Photon S (SLA Resin Printer) | + | * < |
- | Laser Cutter: | + | ====Laser Cutter:==== |
* Ruida controller with 1300mm x 1020mm bed and 130W tube. | * Ruida controller with 1300mm x 1020mm bed and 130W tube. | ||
- | Electronics bench: | + | ====Electronics bench:==== |
* Aouye soldering station with adjustable iron and hot air rework gun. | * Aouye soldering station with adjustable iron and hot air rework gun. | ||
* Adjustable Weller soldering station. | * Adjustable Weller soldering station. | ||
* Fixed temperature Weller soldering station. | * Fixed temperature Weller soldering station. | ||
- | * Korad dual power supply 0-30V 0-3A | ||
- | * Atten digital oscilloscope | ||
- | * Toaster oven modified for reflow soldering. (with profile controller) | ||
* plus a variety of multimeters, | * plus a variety of multimeters, | ||
- | * Spacebox is a reasonably current computer available for use by members and is used for a variety of things including CAD, CAM, embedded programming, | ||
- | * There are also several laptops with Windows 7 and Windows 10 that are available for members' | ||
- | Hand tools: | + | ====Hand tools:==== |
* screwdrivers | * screwdrivers | ||
* pliers | * pliers | ||
Line 35: | Line 29: | ||
* and more | * and more | ||
- | In our "Dirty Room": | + | ====In our "Wood Room":==== |
- | * "Goliath" our CNC router with approximately | + | * "Laguna" our CNC router with approximately |
- | * OMIO X6-2200l CNC router. (Can cut aluminium) | + | |
* large bandsaw with wood blade | * large bandsaw with wood blade | ||
- | * small bandsaw with metal blade | + | * miter saw |
+ | * table saw (Upgraded 2022) | ||
+ | * scroll saw | ||
+ | ====In our "Metal Room": | ||
+ | * OMIO X6-2200l CNC router. (Can cut aluminium) | ||
* large drill press | * large drill press | ||
- | * small drill press | ||
* bench grinder | * bench grinder | ||
- | * scroll saw | ||
* small bench sander | * small bench sander | ||
* cordless drills | * cordless drills | ||
* jigsaw | * jigsaw | ||
* dremel tools | * dremel tools | ||
- | * miter saw | ||
- | * table saw (Upgraded December 2019) | ||
* skilsaw | * skilsaw | ||
* more hand tools | * more hand tools |
